can you fix a leaking brake cylinder. my rear brake doesn't work anymore, or it needs replacement from chan in singapore?
thanks.
peter
thanks.
peter
You can get cylinder rebuild kits, consisting of new seals and 0-rings. As long as the body is OK - no cracks or corrosion - should be fine. A new cover gasket would be a wise choice too.
You just might find that after pricing out the parts, and cost of having it rebuilt if you can not do it yourself, that a new one - complete - is close to the same price. Then it is a simple R and R job.
Don't forget Rule #1
thanks, I have seen a new kit in the EBAY for 30 euros. Meanwhile has been fixed by the pistonshop.
