Body Weight on Cornering
Discussion in 'Motorcycle Roadcraft Forum' started by Nipper, Aug 5, 2010.
  1. Can you answer as to why racing riders move their backside from side to side when cornering?
    Is it to keep the bike more upright to keep more tread on the road or what?
    Hope someone can help.
  2. The seats are very hard and uncomfortable to sit still for more than a few seconds
  3. Because of the extreme lean angles that can be reached with the modern tyre grip that is available, the tyre is at the extreme edge of the contact area and there is nothing left.
    Therefore there is two main reasons to get off to one side of your bike.
    When you apply more throttle whilst leaned fully over the bike will naturally try to lift.
    Getting off the side of the bike and having more weight to one side means that more throttle can be applied and with a relatively higher corner speed and still keeping the bike stable in terms of lean angle change at the corner apex.
    As you exit the corner if you keep your body weight far off the side you can lift the bike onto the fatter section of the tyres and open the throttle a lot earlier and harder than at full lean. If you are sitting upright on the seat the bike would tend to run wide due to understeer.
    Body postion into and out of the corner is not only sideways, to get more front tyre grip you move as far forward as you can to weight up the front tyre.
    There has recently been a dedicated section with the subject related to cornering. Maybe this post should be moved to that section
  4. Thank you for the info, I would also recommend this be moved to the dedicated section.
  5. I was always told to "Keep leanin till yer lips are draggin"! Thus have been hanging off the bike like a monkey ever since. :happy5:
  6. Only Lean as far as you are personally comfortable ....not as your ego or other peoples egos and skill level dictates ,if in doubt slow down and take it easy and always use a bit of negative steering,
  7. Getting off the side also helps in lowering the centre of gravity for the critical maximum lean and turning point and also helps the knee reach the asphalt and create the tripod effect that helps keep the bike more stable while that turning is done.
  8. Cuz it looks cool? ;-)
    [​IMG]
    Ride On!
    Tony :)
