Hiflo oil filters for dirt bikes DR-Z400 YZF WRF RMZ KLX CRF
mussen
143
Hiflofiltro oil filters for dirt bikes. Filters are brand new, are not damaged nor seconds. With o-rings and OEM spec. bypass valves where applicable. Filters are packed in individual boxes, and will be packed safely and clean.
HF141 (replaces OEM part 5TA-13440-00 and 5YP-E3440-00) to suit WR250F/450F, YZ250F/450F
HF112 replaces OEM part numbers, Honda 15410-KFO-010/20, 15410-KL3-670, 15412-KFO-000/305, 15412-KFO-315, Kawasaki 52010-1053, Suzuki K5201-01053, Polaris 308 8036) to suit XR250, xr400, XR600, XR650L, XR650R, KLX140, KLX250, KLX450, KFX450, Polaris 500, DRZ110, Gas Gas 400, Gas Gas 450. Fits the KSR110 also.
HF116 these filters replace the following OEM part numbers, HONDA 15412-MEB-671, HONDA 15412-MEN-671. Fits the following Honda's;
CRF150 R (07-09)
CRF150 RB (07-09)
CRF250 R (04-09)
CRF250 X (04-09)
CRF450 X (05-09)
CRF450 R (02-09)
TRX450 R (04-05)
HF207 These filters replace the following OEM part numbers, KAWASAKI 52010-0001, SUZUKI K5201-00001, SUZUKI 16510-35G00. Fits the following;
SUZUKI RM-Z250 (04-09)
SUZUKI RM-Z450 (05-09)
KAWASAKI KX250F (04-10)
HF139 (these filters replace the following OEM part numbers, Kawasaki 52010-S004, Suzuki 16510-29E00, Arctic Cat 3470-008). Fits the following;
SUZUKI DR-Z400 S (00-09)
SUZUKI DR-Z400 E (00-09)
SUZUKI DR-Z400 SM (05-09)
SUZUKI LT-Z400 (03-09)
SUZUKI LT-R450 (06-09)
KAWASAKI KLX400 R (03)
KAWASAKI KLX400 SR (03)
KAWASAKI KFX400 (05-06)
I've also got the KTM HF155 and HF157 filters
Pack of 5 filters 1000 baht + postage (postage is 100 Baht EMS within Thailand). I'm happy to mix styles.
Mussen. Any bike filter that has an M20 x 1.5 thread. Canister style with at least 17 psi bypass. I will explain.
When i brought my Suzuki VX800 a muppet Thai mechanic was being lazy so rather than order the correct Suzuki oil filter for my bike he went and got a MAZDA one. Fitted it and the bike runs hot (overheat light comes on). I have flushed the rad and it still overheats. I brought a K&N oil filter but when we tried fitting it, no good the thread has been shagged. But another Mazda one went on ok.
The seller tells me no problem before. so i am thinking that the Mazda car filter just is not flowing enough oil. If you can be of help it would be FANTASTIC,
regards Allan
thaicbr wrote: Mussen. Any bike filter that has an M20 x 1.5 thread. Canister style with at least 17 psi bypass. I will explain.
regards Allan
Allan, a Mazda filter should flow plenty of oil. Possibly it is restricting flow because of some other reason...maybe the seal is the wrong size and blocking the oil ports? You should have the fitting tube in the sump repaired or replaced and fit the correct filter. Oil starvation will kill your engine quickly!
Hi Friends,
Please rember me if you could provide as well K & N filters (air and oil) ?
I know there is an official source in LOS, but don't remeber if it was You ?
Should have the HF303 and HF138 back around the end of the week also. Plus a few other filters, PM if you need help with working out which filter you need.
HF303 Fits the following;
CB400
CBR600
CBR1000
YZF-R1
ER6N
Honda, Kawasaki, and Yamaha, dozens of models.
HF138 Fits the following;
Suzuki GSX, various models
Eddie The Eagle wrote: I will need HF 163 for K1200LT & HF 164 for K1200s,
can you supply ?, I bought the last few on a Bike shopping trip to S/pore !.
Eddie
I got mine from Fast corner, both Air and Oil filter, very fast delivery
Hi Eddie, sorry won't have the HF163 and HF164 till the New Year.
I get new stock regularly, and they are cheaper than the K&N and just as good. PM me if you're after a certain filter and I can look at ordering it in for you. If others are after the HF163 and HF164 PM me and I might try to get them earlier.
mussen wrote: I get new stock regularly, and they are cheaper than the K&N and just as good. PM me if you're after a certain filter and I can look at ordering it in for you. If others are after the HF163 and HF164 PM me and I might try to get them earlier.
Mussen
You have then in regular basis in your stock? as when i do my next oil change then i know where to turn?
I have LT as well -04
Marco wrote: [quote quote=mussen]I get new stock regularly, and they are cheaper than the K&N and just as good. PM me if you're after a certain filter and I can look at ordering it in for you. If others are after the HF163 and HF164 PM me and I might try to get them earlier.
Mussen
G'day Marco, might try to get them in a bit earlier if there are a few interested. I was looking at the getting the Bimmer filters in the new Year but it could be mid December.
Cheers.
mussen wrote: [quote quote=Marco][quote quote=mussen]I get new stock regularly, and they are cheaper than the K&N and just as good. PM me if you're after a certain filter and I can look at ordering it in for you. If others are after the HF163 and HF164 PM me and I might try to get them earlier.
Mussen
Cheers.
Mussen
Im no rush yet as i just change them and driven just 2k after that, January-feb is my next scheduled,,so no need to rush for me
HIFLO oil filters HF 163 will fit all R series ie 1100 + 1150 also R1200RT;
Plus all K1200 series, How-ever not recommended for 2005+ new model K1200s,K1200R & K1200GT need HF 164..... Safe riding .. :D
I've got the Hiflofiltro HF171C (chrome) oil filter for Harley Davidson and Buell in stock now. 250baht per filter plus 100baht postage (EMS) within Thailand.
HF163, HF164 (BMW) and the HF138, HF303 are also 250baht per filter plus postage (200baht each + postage for 3 or more filters).
Cheers, Brett
http:/http://maps.google.com/maps?saddr=Ipoh,+Perak,+Malaysia&daddr=D29+to:Jalan+Sungai+Sam+-+Dabong+-+Jeli&hl=en&ll=4.941829,102.150192&spn=0.554797,1.056747&sll=5.691149,101.845279&sspn=0.017316,0.033023&geocode=FaZeRgAdot4GBinjM0DzeezKMTFZ6FJpRp_cjw%3BFZtYSgAdNLITBg%3BFSDjVgAdvAgSBg&mra=mi&mrsp=2&sz=16&t=m&z=11
Dirt bike and street bike oil filters can now be purchased at PornCharoen in BKK (Rama 3 Soi 52, there's a map and phone numbers on their website at Ho Watanatham Nithat). Including,
HF171C (chrome)- Harley Davidson
HF303- CBR, ER6, Versys, XRV (AfricaTwin) + more
HF138- GSX + more
HF204- YZF-R1, CBR, Triumph + more
HF163- BMW
HF164- BMW
Filters are 250baht each, or 200baht each for 3+ filters. Postage is 100baht sent EMS within Thailand.
Sorry Ducati oil filters won't be back until next month.
Brett
Hi Mussen, I am interested in ordering these 2 types of filters, HF-563 and HF-145. Appreciate if you can guide me as to how I could do so. Thank you very much.
Regards,
Zulkifli.
